| Cancel |
Добавлено: Пт Авг 05, 2011 0:50
На форуме с: 16.06.2011
Тип cfg :
Имя игрока :
Код: так то, я на нем играю, уже года полтора
время от времени изменяю
volume
viewsize или 110 или 120
sensitivity
Код: // This file is overwritten whenever you change your user settings in the game.
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "sizedown"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "sizeup"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "amxmodmenu"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "v" "+voicerecord"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "INS" "+klook"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_HOME" "deagle"
bind "KP_UPARROW" "usp"
bind "KP_PGUP" "vesthelm"
bind "KP_LEFTARROW" "m4a1;ak47"
bind "KP_5" "awp"
bind "KP_RIGHTARROW" "vest"
bind "KP_END" "famas; galil"
bind "KP_DOWNARROW" "mp5"
bind "KP_PGDN" "defuser"
bind "KP_INS" "hegren"
bind "KP_DEL" "flash"
bind "MWHEELDOWN" "+jump"
bind "MWHEELUP" ""
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE4" "weapon_hegrenade"
bind "MOUSE5" "weapon_flashbang"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "2"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "600"
cl_crosshair_size "large"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "1"
cl_radartype "1"
cl_righthand "1"
cl_shadows "1"
cl_timeout "300"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "101"
fps_modem "0.0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022000"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0"
mp_decals "300"
net_graph "0"
net_graphpos "2"
net_scale "5"
r_bmodelhighfrac "5.0"
s_a3d "0"
s_automax_distance "30.0"
s_automin_distance "2.0"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000.0"
s_min_distance "8.0"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "2.000000"
skin ""
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "1"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.750000"
volume "0.150000"
setinfo "_vgui_menus" "0"
setinfo "_ah" "0"
setinfo "_pw" ""
+mlook
+jlook
max_shells "120"
max_smokepuffs "120"
rate "25000"
ex_interp "0.1"
zoom_sensitivity_ratio "1.2" |
| ~[ userconfig.cfg.rar ]~
| Описание: |
userconfig.cfg.rar |
1.79 KB |
| Скачано: |
635 раз(а) |
Добавлено: Пт Авг 05, 2011 1:27
Надо снова переходить на оружие, а то совсем стрелять я разучился , сейчас как понакачаю конфигов  |
| xupocuma |
Добавлено: Вс Окт 09, 2011 10:03
На форуме с: 20.07.2011
| а его надо как-то запускать, или он сам будет работать ? |
Добавлено: Вс Окт 09, 2011 10:11
| заменишь userconfig.cfg из архива потом в контре exec userconfig.cfg ну и все! удачи! хотя он помоему дефолтом этот кфг загрузит но лучше прописать!) |
| xupocuma |
Добавлено: Вс Окт 09, 2011 11:44
спасибо
добавлено спустя 21 минуту:
ещё вопросик =))) а как в нём менять звук или там чувствительность мышки ? куда надо зайти ? уж с циферками разберусь, какие поставить =) |
| MazDa |
Добавлено: Вс Окт 09, 2011 12:11
На форуме с: 23.05.2011
s_automax_distance - устанавливает дистанцию для максимальной
громкости
s_automin_distance - устанавливает дистанцию для минимальной
громкости
ambient_level - устанавливает громкость для встроенных звуков
ambient_fade 100 - устанавливает дистанцию, на которой слышны
"включенные в карту" звуки, например опера на cs_italy
sensitivity - устанавливает чувствительность мыши
zoom_sensitivity_ratio - устанавливает чувствительность мыши
с зуммом
А вообще порыскай в инете, определения консольных команд cs, найдёшь подробное описание каждой команды, настроишь cfg как тебе надо. |
| xupocuma |
Добавлено: Вс Окт 09, 2011 12:18
| нееее =) с командами я разберусь. Вот есть у меня файл юзерконфиг и куда надо зайти в нём чтобы это понаписать всё ? Там ( например ) правой кнопкой щёлкнуть в свойства или куда я вот этого не понимаю =) |
| MazDa |
Добавлено: Вс Окт 09, 2011 12:37
| Открой его в виде блокнота. Выглядеть будет как показано у cancela. |
| xupocuma |
Добавлено: Вс Окт 09, 2011 12:54
| спасибо, получилось =) щас нахимичим |
| Rik |
Добавлено: Вс Окт 09, 2011 19:42
На форуме с: 10.11.2009
| Поставил,немного поиграл.Но вот мне интересно,ни разу не пробовал в кфг менять мешеньку,ну там большая средняя,маленькая.Какая команда ? На самом деле просто неохото искать в инете. |
Добавлено: Вс Окт 09, 2011 20:54
| crosshair_size "small" "medium" "large" - выбор за тобой :D:D |
| Rik |
Добавлено: Вс Окт 09, 2011 21:28
| Не смейся,просто как-то не доводилось пользоваться =) |
Добавлено: Вс Окт 09, 2011 21:49
| кто смеялся? я до сих пор не меняю прицел - разрешение 1280 на 1024 прицел medium желтый непрозначный! |
