Список форумов * PWR FACTORY *  -  Баны серверов  -  Aero
Добавлено: Ср Дек 12, 2012 15:53
[AMXBans] Вы были забанены на этом сервере админом [PWR Guard].
[AMXBans] Осталось 10 часов, 6 минут and 23 секунд до окончания бана.
[AMXBans] Ник: Aero
[AMXBans] Причина: 'Обнаружен [ Spin hack ]'
[AMXBans] Ваш SteamID: 'STEAM_0:0:1461601234'
[AMXBans] Ваш IP: '178.64.159.169'
Invalid file type...skipping download of ../opengl32.dll
Kicked : Пошёл вон!!Зайди на http://pwrfactory.ru/bans возможно В
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "sizedown"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "sizeup"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F3" "menu"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "INS" "eiriobvdeyqmpus_INS"
bind "DEL" "eiriobvdeyqmpus_DEL"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "HOME" "eiriobvdeyqmpus_HOME"
bind "END" "eiriobvdeyqmpus_END"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1.000000"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "600.000000"
cl_crosshair_size "small"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Green"
cl_logofile "devl1"
cl_lw "1"
cl_minmodels "0"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "300"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "72.0"
fps_modem "0.0"
gamma "2.500000"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "4"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "0"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0.800000"
mp_decals "300.000000"
name "Aero"
net_graph "0"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0.0"
s_automax_distance "30.0"
s_automin_distance "2.0"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0.0"
s_leafnum "0"
s_max_distance "1000.0"
s_min_distance "8.0"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "20"
skin ""
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "2"
volume "0.5"
setinfo "_vgui_menus" "1"
setinfo "_ah" "1"
+mlook
+jlook
exec userconfig.cfg
~[ 35hp_lava20000.bmp ]~
 Скачано:  806 раз(а)
RampaGe
Добавлено: Ср Дек 12, 2012 15:55
Ты конфиг менял?
Winter is coming
Добавлено: Ср Дек 12, 2012 16:01
Он вертел мышкой и его забанил гвард, по его словам.
Скопируй содержимое config.cfg сюда. Он находится в папке cstrike. Открыть можно с помощью блокнота. Или же заархивируй его и приложи сюда, как и скриншот.
RampaGe
Добавлено: Ср Дек 12, 2012 16:12
Обычно у задротов или школяров с кнайфа всегда конфиги другие, скорее его конфиг называется иначе.
Winter is coming
Добавлено: Ср Дек 12, 2012 16:13
Я играю честно у меня конфиг чист и играю только на ПВР
Добавлено: Ср Дек 12, 2012 16:14
Да я не прошу его конфиг. Мне нужен основной, куда копируются данные из личного кфг.
RampaGe
Добавлено: Ср Дек 12, 2012 16:16
Многие просто при заходе в игру прописывают его.
Winter is coming
Добавлено: Ср Дек 12, 2012 16:17
Я опять что-то не то сделал
RampaGe
Добавлено: Ср Дек 12, 2012 16:18
При входе в игру ты что-нибудь прописываешь в консоль?
Winter is coming
Добавлено: Ср Дек 12, 2012 16:20
Нет
RampaGe
Добавлено: Ср Дек 12, 2012 16:24
Значит надо из Гуарда убрать бан за [Spin Hack], это ведь из-за того, что мышью крутишь?
Winter is coming
И тем самым копирует информацию из личного кфг в рабочий клиента.
На основе своих небольших знаний ничего лишнего в кфг не заметил. На удивление, алиасов вообще нет.
Кстати, hit, советую изменить fps_max 72 на fps_max 100. Думаю, почувствуешь разницу.
Его тестил Интакто. Крутил очень долго и его забанило. Просто не крутите столько.
Добавлено: Ср Дек 12, 2012 16:25
Скорее всего ложный бан, такойже как и у Алекса был. Спин хак - это чит когда чувак бежит и крутится, раздавая всем хедшопы, направо и налево.
Если крутить мышкой много и специально, то может забанить, Гровер это подтверждал - мувиком.
Добавлено: Ср Дек 12, 2012 16:27
Всё я разбанен.
Добавлено: Ср Дек 12, 2012 16:30
Всё я разбанен.
Удивил.)
На этом всё тогда.
