| h1t^^ |
Добавлено: Ср Дек 12, 2012 15:53
[AMXBans] Вы были забанены на этом сервере админом [PWR Guard].
[AMXBans] Осталось 10 часов, 6 минут and 23 секунд до окончания бана.
[AMXBans] Ник: Aero
[AMXBans] Причина: 'Обнаружен [ Spin hack ]'
[AMXBans] Ваш SteamID: 'STEAM_0:0:1461601234'
[AMXBans] Ваш IP: '178.64.159.169'
Invalid file type...skipping download of ../opengl32.dll
Kicked : Пошёл вон!!Зайди на http://pwrfactory.ru/bans возможно В
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "sizedown"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "sizeup"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F3" "menu"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "INS" "eiriobvdeyqmpus_INS"
bind "DEL" "eiriobvdeyqmpus_DEL"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "HOME" "eiriobvdeyqmpus_HOME"
bind "END" "eiriobvdeyqmpus_END"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1.000000"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "600.000000"
cl_crosshair_size "small"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Green"
cl_logofile "devl1"
cl_lw "1"
cl_minmodels "0"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "300"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "72.0"
fps_modem "0.0"
gamma "2.500000"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "4"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "0"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0.800000"
mp_decals "300.000000"
name "Aero"
net_graph "0"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0.0"
s_automax_distance "30.0"
s_automin_distance "2.0"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0.0"
s_leafnum "0"
s_max_distance "1000.0"
s_min_distance "8.0"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "20"
skin ""
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "2"
volume "0.5"
setinfo "_vgui_menus" "1"
setinfo "_ah" "1"
+mlook
+jlook
exec userconfig.cfg |
| ~[ 35hp_lava20000.bmp ]~
| Описание: |
35hp_lava20000.bmp |
900.05 KB |
| Скачано: |
825 раз(а) |
| RampaGe |
Добавлено: Ср Дек 12, 2012 15:55
На форуме с: 05.07.2012
| Ты конфиг менял? |
Winter is coming |
Добавлено: Ср Дек 12, 2012 16:01
Он вертел мышкой и его забанил гвард, по его словам.
Скопируй содержимое config.cfg сюда. Он находится в папке cstrike. Открыть можно с помощью блокнота. Или же заархивируй его и приложи сюда, как и скриншот. |
| RampaGe |
Добавлено: Ср Дек 12, 2012 16:12
| Обычно у задротов или школяров с кнайфа всегда конфиги другие, скорее его конфиг называется иначе. |
Winter is coming |
| h1t^^ |
Добавлено: Ср Дек 12, 2012 16:13
Цитата: Обычно у задротов или школяров с кнайфа всегда конфиги другие, скорее его конфиг называется иначе.
Я играю честно у меня конфиг чист и играю только на ПВР |
Добавлено: Ср Дек 12, 2012 16:14
Цитата: скорее его конфиг называется иначе.
Да я не прошу его конфиг. Мне нужен основной, куда копируются данные из личного кфг. |
| RampaGe |
Добавлено: Ср Дек 12, 2012 16:16
Многие просто при заходе в игру прописывают его. |
Winter is coming |
| h1t^^ |
Добавлено: Ср Дек 12, 2012 16:17
Да я не прошу его конфиг. Мне нужен основной, куда копируются данные из личного кфг. Я опять что-то не то сделал |
| RampaGe |
Добавлено: Ср Дек 12, 2012 16:18
Цитата: Я опять что-то не то сделал
При входе в игру ты что-нибудь прописываешь в консоль? |
Winter is coming |
| h1t^^ |
Добавлено: Ср Дек 12, 2012 16:20
| RampaGe |
Добавлено: Ср Дек 12, 2012 16:24
| Значит надо из Гуарда убрать бан за [Spin Hack], это ведь из-за того, что мышью крутишь? |
Winter is coming |
Цитата: Многие просто при заходе в игру прописывают его.
И тем самым копирует информацию из личного кфг в рабочий клиента.
На основе своих небольших знаний ничего лишнего в кфг не заметил. На удивление, алиасов вообще нет.
Кстати, hit, советую изменить fps_max 72 на fps_max 100. Думаю, почувствуешь разницу.
Цитата: Значит надо из Гуарда убрать бан за [Spin Hack], это ведь из-за того, что мышью крутишь?
Его тестил Интакто. Крутил очень долго и его забанило. Просто не крутите столько. |
Добавлено: Ср Дек 12, 2012 16:25
Скорее всего ложный бан, такойже как и у Алекса был. Спин хак - это чит когда чувак бежит и крутится, раздавая всем хедшопы, направо и налево.
Если крутить мышкой много и специально, то может забанить, Гровер это подтверждал - мувиком. |
| h1t^^ |
Добавлено: Ср Дек 12, 2012 16:27
Добавлено: Ср Дек 12, 2012 16:30
Удивил.)
На этом всё тогда.
