Список форумов * PWR FACTORY *  -  PWR FACTORY - Only Knife  -  Проблема балансировки команд сервер Knife
Добавлено: Пн Фев 11, 2019 9:05
До меня дошла информация о проблемах балансировки команд на сервере.
Вы бы хотябы тему создавали, если есть проблемы.
С чего вы взяли что там не стоит вообще балансер, он стоит:
https://forums.alliedmods.net/showthread.php?p=705142
* It is modified by Safety1st plugin not the original!
* See one here: https://forums.alliedmods.net/showthread.php?t=79556
* Changes are:
* - fixed appearing 'Auto-Team Balance next round' on the screen, thx to ConnorMcLeod.
/* Copyright ゥ 2008, ConnorMcLeod
Instant AutoTeamBalance is free software;
you can redistribute it and/or modify it under the terms of the
GNU General Public License as published by the Free Software Foundation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with Instant AutoTeamBalance; if not, write to the
Free Software Foundation, Inc., 59 Temple Place - Suite 330,
Boston, MA 02111-1307, USA.
#include <amxmodx>
#include <cstrike>
#define PLUGIN "Instant AutoTeamBalance"
#define AUTHOR "ConnorMcLeod"
#define VERSION "1.2.0"
#define BALANCE_IMMUNITY ADMIN_RCON
#define MAX_PLAYERS 32
enum {
aTerro,
aCt
new bool:g_bImmuned[MAX_PLAYERS+1]
new Float:g_fJoinedTeam[MAX_PLAYERS+1] = {-1.0, ...}
new g_iMaxPlayers
new g_pcvarEnable, g_pcvarImmune, g_pCvarMessage
// true when connected and not a HLTV
new bool:g_bValid[MAX_PLAYERS+1]
new iMsgTextMsg
public plugin_init()
register_plugin(PLUGIN, VERSION, AUTHOR)
g_pcvarEnable = register_cvar("iatb_active", "1")
g_pcvarImmune = register_cvar("iatb_admins_immunity", "1")
g_pCvarMessage = register_cvar("iatb_message", "Teams Auto Balanced")
register_logevent("LogEvent_JoinTeam", 3, "1=joined team")
register_event("TextMsg", "Auto_Team_Balance_Next_Round", "a", "1=4", "2&#Auto_Team")
g_iMaxPlayers = get_maxplayers()
iMsgTextMsg = get_user_msgid("TextMsg")
public LogEvent_JoinTeam()
new loguser[80], name[32], id
read_logargv(0, loguser, 79)
parse_loguser(loguser, name, 31)
id = get_user_index(name)
g_fJoinedTeam[id] = get_gametime()
public client_authorized(id)
g_bImmuned[id] = bool:(get_user_flags(id) & BALANCE_IMMUNITY)
public client_putinserver(id)
g_bValid[id] = bool:!is_user_hltv(id)
public client_disconnect(id)
g_bValid[id] = false
public Auto_Team_Balance_Next_Round()
if(!get_pcvar_num(g_pcvarEnable))
return
if( balance_teams() )
new szMessage[128]
get_pcvar_string(g_pCvarMessage, szMessage, charsmax(szMessage))
// this is needed instead of client_print() for correct overlapping
message_begin( MSG_ALL, iMsgTextMsg, _, 0 )
write_byte(print_center)
write_string(szMessage)
message_end()
cs_set_user_team_custom(id, CsTeams:iTeam)
switch(iTeam)
case CS_TEAM_T:
if( cs_get_user_defuse(id) )
cs_set_user_defuse(id, 0)
// set body to 0 ?
case CS_TEAM_CT:
if( user_has_weapon(id, CSW_C4) )
engclient_cmd(id, "drop", "weapon_c4")
cs_set_user_team(id, iTeam)
return 1
balance_teams()
new aTeams[2][MAX_PLAYERS], aNum[2], id
for(id = 1; id <= g_iMaxPlayers; id++)
if(!g_bValid[id])
continue
switch( cs_get_user_team(id) )
case CS_TEAM_T:
aTeams[aTerro][aNum[aTerro]++] = id
case CS_TEAM_CT:
aTeams[aCt][aNum[aCt]++] = id
default:
continue
new iCheck
new iTimes = aNum[aCt] - aNum[aTerro]
if(iTimes > 0)
iCheck = aCt
else if(iTimes < 0)
iCheck = aTerro
else
return 0
iTimes = abs(iTimes/2)
new bool:bTransfered[MAX_PLAYERS+1],
bool:bAdminsImmune = bool:get_pcvar_num(g_pcvarImmune)
new iLast, iCount
while( iTimes > 0 )
iLast = 0
for(new i=0; i <aNum[iCheck]; i++)
id = aTeams[iCheck][i]
if( g_bImmuned[id] && bAdminsImmune )
continue
if(bTransfered[id])
continue
if(g_fJoinedTeam[id] > g_fJoinedTeam[iLast])
iLast = id
if(!iLast)
return 0
cs_set_user_team_custom(iLast, iCheck ? CS_TEAM_T : CS_TEAM_CT)
bTransfered[iLast] = true
iCount++
iTimes--
return 1
Плагин активируется при переходе сервера в ДМ режим.
В своё время всё работало, сейчас не знаю, вы все молчите...
Doormouse
Добавлено: Пн Фев 11, 2019 9:36
Онлайн
Балансер стоит, ток срабатывает он по окончании раунда. То есть в режиме дм не совсем подходит. Больше беспокоит что некоторые игроки не могут возродиться при попытке зайти на сервер или при смене команды.( перезаходить приходится иногда по несколько раз)
Добавлено: Пн Фев 11, 2019 9:42
В том то и дело балансер стоит именно тот, который должен работать не дожидаясь конца раунда.
Doormouse
Добавлено: Пн Фев 11, 2019 10:31
Онлайн
тогда это странно. Sad
VALENAK
Добавлено: Пн Фев 11, 2019 10:39
На форуме с: 06.02.2019 Возраст: 31 Сообщения: 79
Можно же попробовать и другой балансер поставить если этот не работает так как должен работать.
По поводу возрождения нужен другой knife dm и будет у вас спавн нормальный и застревать никто не будет. Вот обе ссылки https://ru.files.fm/u/fa3zhrkd https://ru.files.fm/u/qgng6qp6
Добавлено: Пн Фев 11, 2019 10:51
Ок, а что будет делать твой балансировщик когда будет выбран классический режим?
Плагин кнайф дма у нас стоит от этого же автора, только более свежей версии, баг скорее всего не в нем.
Плюс интересные рекламные записи в плагине))
client_print(id, print_chat, "IP : [ 146.255.195.50:27036 ]")
client_print(id, print_chat, ":Dep3kuu Knife DM [+18]")
Бля как вспомню этот сервер и в дрож бросает))), какой ахтунг там творили администраторы)))
VALENAK
Добавлено: Пн Фев 11, 2019 12:28
это мой сервер
    - добавлено спустя 5 минут:
Нормальные админы были они хотя бы были))
Добавлено: Пн Фев 11, 2019 12:36
Вероятно, со словом "качество" ты не знаком. Как это грустно. Но цивилизация не до всех дошла. А иногда и эволюция.
