Список форумов * PWR FACTORY *  -  Новости и предложения по серверам  -  Новый билд серверов CS 1.6 (7559)
Добавлено: Пн Фев 19, 2018 12:37
На форуме с: 25.10.2009 Возраст: 32 Сообщения: 7700 Откуда: Питер
Только сегодня узнал, что Valve билд серверов CS 1.6 в июле 2017 года.
Вот changelog от Вальвы:
Changes in this update are:
Fixed crash when entering certain malformed strings into the game console. Thanks to Marshal Webb from BackConnect, Inc for reporting this.
Fixed crash when loading a specially crafted malformed BSP file. Thanks to Grant Hernandez (@Digital_Cold) for reporting this.
Fixed malformed SAV files allowing arbitrary files to be written into the game folder. Thanks to Vsevolod Saj for reporting this.
Fixed a crash when quickly changing weapons that are consumable. Thanks to Sam Vanheer for reporting this.
Fixed crash when setting custom decals
Make sure the Close button has keyboard focus when you see the disconnection dialog
Disable showing of popup html windows
Made the play command obey speak_enabled cvar
Fixed being unable to pickup a primary weapon if you had an ammox box object previously stip you of items
Fixed room type not being updated on map change/connect
Fixed out of date information showing in the scoreboard after level change or changing servers
Fixed the specator UI to not show a placeholder name when initially shown
Fixed sprays not loading from the correct path causing them not to update
Fixed the Condition Zero tours ui to display the tour number correctly when you have more than 9 entries
Fixed crash if you issued a changelevel command on a local server while certain UI elements were visible
Чтобы избежать всякие проблемы с новым билдом, он был поставлен для теста, на Классический сервер. Плагины судя по консоли все запустились. модули тоже. Но желательно чтобы, кто-нибудь проверил на нём голосовой чат, ну или вдруг заметите какие-то проблемы пишите сюда!
Добавлено: Пн Фев 19, 2018 12:42
* Консультант *
* Консультант *
На форуме с: 13.08.2011 Возраст: 32 Сообщения: 5543
Со всех серверов?
Добавлено: Пн Фев 19, 2018 13:10
    - добавлено спустя 13 минут:
Добавил классик на пару кругов в буст, чтобы протестить.
Добавлено: Пн Фев 19, 2018 20:02
* Консультант *
* Консультант *
Голосовой чат проверен.
После автопрогона на классике будем пытаться завести на живом сервере. Надеюсь, наши плагины успешно переживут этот апдейт.
Добавлено: Пн Фев 19, 2018 21:45
Да скорее всего, не думаю что они что-то глобальное там делали, это же Вальве
Добавлено: Ср Фев 21, 2018 10:29
Обновил билд на всех серверах. Если заметите какие-то проблемы, пишите.
Doormouse
Добавлено: Ср Фев 21, 2018 12:55
На форуме с: 24.12.2013 Возраст: 27 Сообщения: 264
кнафе пропал выбор режима.. Теперь всегда класик
Добавлено: Ср Фев 21, 2018 14:41
Только что зашёл на Кнайф там Деатматч стоит. Также зашёл на ГГ и проверил работу вбыора режима, также всё работает.
Doormouse
Добавлено: Ср Фев 21, 2018 15:31
хм, странно.. я днем два раза перезапускал карту , но выбор так и не появился... Rolling Eyes
Добавлено: Ср Фев 21, 2018 16:11
Я выбор не проверял, просто зашёл смотрю стоит ДМ. А на ГГ проверил, там такой же стоит плагин. Если что напиши, если действительно не будет появляться.
Doormouse
Добавлено: Ср Фев 21, 2018 23:31
Сейчас три раза сменил карту. два раза через амх меню и один раз ртв.. выбора режима так и не было.. Я был один на сервере.. Может когда один игрок такая фигня ?
4 раза ((
    - добавлено спустя:
С появлением хлтв все заработало. Видать когда один игрок на сервере что то не работает.
Добавлено: Чт Фев 22, 2018 19:00
Значит плагин не запускает голосование когда на сервере 1 игрок, что логично, наверное автор плагина это учёл, либо у меня он так настроен, я уже и не помню.
